salextx64.dll
mesajflaviu
salextx64.dll
Post by mesajflaviu »
I have on my HDD a folder as308sdk, to test your software. And when I have tried to delete it, I cannot delete two files: salextx64.dll and salextx86.dll. I have seek it on registry, and I deleted from there, but I still cannot delete these files from HDD .. .why ? Can you help me ?
Re: salextx64.dll
these are shell extensions.
Try to unregister them from an elevated command prompt using
regsvr32 /u <file.dll>
(Replace <file.dll> with absolute or relative path to the files in use by the system.)
Then, after a reboot, you should be able to delete them.
mesajflaviu
Re: salextx64.dll
Yes, it worked. Thank you.
