Convert ctrl-k
Posted: 09 Dec 2019, 13:40
by monnybg
Can i use conbert with command line comands or dos bat file?
Re: Convert ctrl-k
Posted: 23 Dec 2019, 16:22
by tukanos
monnybg wrote: 09 Dec 2019, 13:40
Could you elaborate more on your question? What exactly are you trying to achieve and how. I admit I don't understand your question.
Re: Convert ctrl-k
Posted: 23 Dec 2019, 18:48
by therube
I start File Comparator from a command-line (or otherwise), but it has an .exe to call (fcremote.exe).
Not sure if Convert is a plugin ? & if so, which plugin it is?
And then there is no .exe associated with it, so... & not sure if you can "call" a .spl (even if it is an "executable"), so... not sure?
