4.0 (x64) UnISO Plugin
I downloaded an ISO file and when I wanted to open it in Salamander (pressing Enter), Windows 10 created a virtual drive instead and mounted the ISO there.
The plugin is installed, tests ok, and lists "List and unpack Archive in Panel" in Functions.
  • Is there anything else in configuration I need to check?
  • Is there any way a I can force Salamander to open it?
  • Is there a problem with the plugin?
Re: 4.0 (x64) UnISO Plugin
Ok, found it.
The Plugin needs to be configured in "Archives Associations in Panels", where it was missing.
I am still interested in an answer to
in case the file extension does not match one of the list configured.
SvA wrote: 20 Nov 2019, 14:07 Ok, found it.
You need to change the file association for an *.iso file in windows. If you set it to salamander it will open the iso file via salamander.
Hi tukanos,
since when can you start Salamander with a file on the command line?
Unless you have DDE, the command line is the only way to utilize for file associations.
But, as I wrote, I found the solution for Salamander not opening the .iso in it's panel.
The question that remains open is how to force Salamander to use an available unpacker on a file that is not associated with the unarchiver already, e.g. a Microsoft Word .docx file, which of course needs to open in Word by default, even in Salamander, but at times i'd like to get at some resource within the document. UnZip would work well, but I need to unpack the file in order to inspect its contents.
SvA wrote: 22 Nov 2019, 19:35 Hi tukanos,
I'm afraid I don't understand you. You can just open the *.iso file as being archive like this (using UNISO plugin):
Hi tukanos,
not if the entry in "Archives Associations in Panels" is missing, as I wrote in my follow-up post
SvA wrote: 25 Nov 2019, 17:23 Hi tukanos,
Hi SvA,
Now I'm in picture. What confused me is the missing configuration. I have a default install present but this configuration was there.
You can't, because there is no file introspection from the windows side. Microsoft decided, very stupid decision, but made their life easier, to treat all files based on suffix. So the only way would be to create a macro which would rename the file first.
