Deleting empty undeleted files
Posted: 22 Feb 2006, 15:28
by mdruiter
After I undeleted an empty (0 bytes) file using the plugin, the resulting file cannot be deleted again. The message I get is:
Error Deleting File
Error: (32) The process cannot access the file because it is being used by another process.
It does not work until I close Salamander. Apparently the plugin keeps such a file open?
Reply?
Posted: 22 Feb 2006, 15:45
by mdruiter
The post was mine, but I did not log in until now. Please reply to this one instead!
Posted: 22 Feb 2006, 18:01
by cincura.net
Can you rename the folder where the file is?
Posted: 23 Feb 2006, 09:12
by mdruiter
No, that gives me:
Error Renaming File
(5) Access is denied
Posted: 23 Feb 2006, 11:11
by cincura.net
mdruiter wrote:No, that gives me:
Error Renaming File
This seems, that the plugin has setted the working directory into the directory, so you're not able to delete files and/or folders.
Maybe the author of the plugin will say more.
Re: Deleting empty undeleted files
Posted: 23 Feb 2006, 17:18
by jis
Process Explorer http://www.sysinternals.com/Utilities/P ... lorer.html can explain what program lock the file.
I prepare file with length 0 bytes. I delete it (without recycle bin). Then I restore it with undelete plugin to different partition and really, restored file was locked. But not with the plugin (I unload the plugin from the memory), but with SALAMAND.exe as an handle.
Posted: 23 Feb 2006, 17:25
by cincura.net
jis wrote:But not with the plugin (I unload the plugin from the memory), but with SALAMAND.exe as an handle.
Yes, cause' the plugin is loaded by SS.
I think Altap should fix this. ;)
Posted: 28 Feb 2006, 11:57
I can reproduce this problem. Thank you for reporting it!
Posted: 01 Mar 2006, 00:08
by jis
It was problem of plugin or Salamander itself?
Posted: 01 Mar 2006, 09:42
jis wrote:It was problem of plugin or Salamander itself?
Don't know now, we will let you know...
Posted: 05 May 2006, 14:24
Problem was fixed in SS 2.5 RC1. Could you please confirm it?
Posted: 06 May 2006, 00:53
by jis
Jan Rysavy wrote:Problem was fixed in SS 2.5 RC1. Could you please confirm it?
Yes, I could. Thank you.
Posted: 08 Dec 2009, 22:54
by mdruiter
Confirmed, I guess this post can be flagged as fixed.
