Crash on viewing a CSV file
Yuriy
Post by Yuriy »
Altap Salamander 4.0 always crashes for me when viewing a CSV file.
There was no such problems in 3.08, and other CSV file are shown correctly...
speedtestpc.csv
(4.07 KiB) Downloaded 8678 times
Re: Crash on viewing a file
Nice one, Salamander 4.01 is obviously coming soon. Thank you Yuriy!
Fix for version 4.0 is attached. Just unpack over existing version (x64 version is in C:\Program Files\Altap Salamander, x86 version in C:\Program Files (x86)\Altap Salamander). Enjoy. ;-)
dbviewer-1.24.7z
(128.42 KiB) Downloaded 10912 times
Yuriy
Post by Yuriy »
Thanks for the patch, it works :)
pfe
Post by pfe »
Petr Solin wrote: 01 Jul 2019, 22:53 Fix for version 4.0 is attached. Just unpack over existing version (x64 version is in C:\Program Files\Altap Salamander, x86 version in C:\Program Files (x86)\Altap Salamander). Enjoy. ;-)
Wouldn't it be nice if this fix was automatically delivered via the checkVersion plugin?
mdruiter
Post by mdruiter »
I think this fix should be more prominent. All users (including new ones, now that Salamander is free) are downloading and using a version that is known to be broken!
jis
Post by jis »
Jan Rysavy wrote: 01 Jul 2019, 15:59 Nice one, Salamander 4.01 is obviously coming soon. Thank you Yuriy!
Salamander 4.01 apparently did not arrive soon :(
jis wrote: 09 Apr 2021, 23:30 Salamander 4.01 apparently did not arrive soon :(
... but a fix for the buggy extension. See 3rd post above.
mdruiter
Post by mdruiter »
Sure. But that's only for existing users who know about (and read) this forum! :(
maroon
Post by maroon »
Are there any more patches like this? I only found out about the patch when I just now tried to report this same bug, so it would be helpful if any patches could be referenced in a sticky at the top of the forum, at the very least.
I tested again to see if the zip-destroying bug is still there, and it is. viewtopic.php?f=2&t=37379
The creators of Salamanders have permission from Fine ltd. to work on Salamander. They will patch these lose ends. You can read (in Czech) - @ viewtopic.php?p=71747#p71747
sylvaing
Post by sylvaing »
mdruiter wrote: 12 Apr 2021, 21:01 Sure. But that's only for existing users who know about (and read) this forum! :(
Indeed. I just stumbled here. I've been using Salamander since the early nineties (and we paid for an educational V2 version way back then) and that bug with 4.0 was very annoying. I decided today to check if an update was available and nope, then decided to check the forum and OMG! YES!!! No more crash! And that was way back in 2019!!! I wish I would have known back then. Anyway, now may coworkers also know about it.
stepan.hasek
Re: Crash on viewing a CSV file
Post by stepan.hasek »
Yeah, just checking if there is anythink new with Salamander and get across this thread and found out there is bugfix for this bug which is annoying me for so long.
I am very sad about situation with Salamander.
