Folders Windows 7
Posted: 17 Nov 2010, 19:46
by triplexxx
Hallo!
Altap Salamander 2.54 displays Links in Windows 7 as Directorys. E.g. Documents and Settings.
Is that a bug?
Regards
triplexxx
Re: Folders Windows 7
Posted: 17 Nov 2010, 21:40
It works as desired, we don't see the problem...
Posted: 17 Nov 2010, 22:42
by triplexxx
Please see the two pictures. The first shows how Total Commander handles Directories and Links, the second one how Altap Salamander does.
Picture 1:
http://img821.imageshack.us/img821/7426/image002iva.jpg
Picture 2:
http://img842.imageshack.us/img842/3946/image004c.jpg
It seems, that Altap Salamander makes no difference between Directories and Links.
Bug or Feature?
Best Regards
triplexxx
Posted: 18 Nov 2010, 00:13
by Ether
triplexxx wrote:Bug or Feature?
Neither. Your observation is inaccurate, because there's another overlay on the icon that takes precedence. If you disable the SharingPrivate overlay in
Options > Configuration... > Icon Overlays, you will see the "link" overlay.
Anyway, is there any other aspect to the difference of links and directories you expected to see, other than their icon?
Posted: 18 Nov 2010, 00:39
by triplexxx
That was it!
But why does Altap Salamander mark a Link as a Directory? (in difference to Total Commander - Picture 1)
Best Regards
triplexxx
Posted: 18 Nov 2010, 12:15
by Ether
triplexxx wrote:But why does Altap Salamander mark a Link as a Directory
Because it's a link to a directory and therefore behaves as one. If you create a link to a file, you can view the contents, maybe execute it, like a real file. If you create a link to a directory, you can open it and explore the files inside. If you have a different opinion on how links should be presented and why, please do tell.
Posted: 18 Nov 2010, 13:50
by triplexxx
mhh ...I agree, but I think it should be named as "Link" in the Salamander Window (like Total Commander does), a not as "Directory" because it's no directory, only behaves as one .... I can see it now on the icon, that it is a Link, but it is named as Directory ... an that's what I do not understand.
Posted: 18 Nov 2010, 14:14
Moving this thread to Feature requests.
