HotKeys for User Menu Bar items
Posted: 17 Oct 2010, 00:40
by crystalidea
subj :)
Re: HotKeys for User Menu Bar items
Posted: 17 Oct 2010, 17:48
Use '&' character in command name to define User Menu hot keys.
Posted: 17 Oct 2010, 21:19
by crystalidea
Sorry, can't get it work.
Posted: 17 Oct 2010, 23:01
by Ether
Could you post a screenshot of the User Menu Configuration dialog and of the corresponding User Menu opened in a panel?
Posted: 17 Oct 2010, 23:12
by crystalidea
When I press F9 first, i see my command, and the letter after & symbol is underlined.
Posted: 17 Oct 2010, 23:29
by Ether
XPiS wrote:When I press F9 first, i see my command, and the letter after & symbol is underlined.
Yeah, that's correct, now you can press F9 and then the underlined letter to invoke that command.
Posted: 17 Oct 2010, 23:46
by crystalidea
Ether,
Thank you, it works.
