Change Path by Pasting
In AS 2.54 Paste (Change Directory) does not work if the path is surrounded by double quotes.
I don't know about the behaviour in earlier versions, but AS should cope with quoted paths, as this is the standard for paths with whitespaces in most cases.
Re: Change Path by Pasting
Just curious, in what circumstances are you coming across paths with quotes?
ino
Post by ino »
+1
therube wrote:Just curious, in what circumstances are you coming across paths with quotes?
For example copy of target path of any shorcut of anything within Program files folder.
I will move this thread to Feature requests section. I'm missing the double quotes stripping too.
mdruiter
Post by mdruiter »
I'd like to bump this issue.
As I see it, it is just a small and local change ... please do it.
Fixed. Will be included in AS 2.55 EAP.
