Display number of items in directory?
rotvel
Post by rotvel »
I'm probably overlooking it, but is there a way to automatically have the number of items in a directory displayed?
Regards
/Max
Jeffin90620
Re: Display number of items in directory?
Post by Jeffin90620 »
When you select files, Salamander tells you how many have been selected.
Type <Ctrl>-A to select everything (or use the Numeric Keypad's '+' key to enter a selection wildcard) and Salamander will tell you how many files have been selected (also directories, if relevant).
Jeff
See also:
Calculating Directory Sizes, Ctrl+Shift+F10
Calculating Occupied Space, Alt+F10
& (don't know what its called, but) pressing the spacebar on a directory entry
Perhaps even an RFE to display count of Files/(sub)Directories (in addition to the currently given size/(top level) directories), at the least for the last item I mentioned above. Such display could appear on the Directory line itself, or at the least on the status line.
