Confirm Alternate Data Stream Loss
Hi, is it possible to witch this warning off? I get before every copy action this annoying warning message, that I'll lose ADS information.
Regards, olli. Using 2.5 Beta 11
Re: Confirm Alternate Data Stream Loss
This warning is very useful. You probably want to copy files from NTFS to FAT or FAT32?ollixx77 wrote:Hi, is it possible to witch this warning off? I get before every copy action this annoying warning message, that I'll lose ADS information.
Citation from http://en.wikipedia.org/wiki/Alternate_data_stream:
You can have data loss when sending files via fork unaware channels (e-mail, filesystems without multiple forks support -or even when copying between filesystems with forks support, if the program that made the copy is unaware-, compressed archives) and not be aware of that.
Ok, so solution for you will be probably new item in Confirmations in Options for ADS Operations.ollixx77 wrote:I know that I loose some additional data when I copy files from NTFS to FAT. ADS is used so far only for thumnails, XP Zone Identifer and some viruses. All things which I can forego.
I am just curious. Which one from three examples you mentioned is responsible for excessive number of warnings when you are copying files from NTFS to FAT? I suppose, that you don't have so much stealth viruses on your system
You still do your downloads by plain IE?
No, Im using Opera.
The ADS seem to result mostly from an antivirus programm. A tool from http://www.sysinternals.com/Utilities/Streams.html revealed several streams with this data ":KAVICHS:$DATA 36". The usenet say its from Kaspersky AV. I think I'll delete all ADS information on my data partition, because I don't use this virus scanner anymore.
I can recommend this small and fast tool:ollixx77 wrote:I think I'll delete all ADS information on my data partition, because I don't use this virus scanner anymore.
ADS Spy
http://www.richardthelionhearted.com/~m ... loads.html
A small tool to list, view or delete Alternate Data Streams (ADS) on Windows 2000/XP with NTFS file systems. ADS is a way of storing meta-information for files without actually storing the information in the file it belongs to, carried over from early MacOS compatibility from Windows NT4. Recently browser hijackers began using this technique to store hidden information on the system, and even store trojan executable files in ADS streams of random files on the system. Use with caution.
I think the best solution would be to add a new item in Confirmations in Options for ADS Operations. Please, don't throw away some ADS and others not.Petr Solin wrote:I think the best would be to add Kaspersky AV ADS to list of ADS which can be lost without problem (as thumbnails under Win2K). I have already sent email to ollixx77 with utility for listing ADS. When I receive results (precise name of that ADS), I will patch it.
If I do it as you suggest, all users with Kaspersky AV will probably turn off this ADS Loss warning, because it's really annoying and useless when informing only about some AV data that are generated automatically. And I still think that all ADS of unknown type can be important, so it would not be reasonable to ignore them. That's why I don't want to make ADS Loss warning optional.jis wrote:I think the best solution would be to add a new item in Confirmations in Options for ADS Operations. Please, don't throw away some ADS and others not.
So what about compromise: Add a new item in Confirmations in Options for ADS Operations, but for turning on/off ADS Loss warning only for known types? Isn't this better than silently ignore known ADS?Petr Solin wrote:If I do it as you suggest, all users with Kaspersky AV will probably turn off this ADS Loss warning, because it's really annoying and useless when informing only about some AV data that are generated automatically. And I still think that all ADS of unknown type can be important, so it would not be reasonable to ignore them. That's why I don't want to make ADS Loss warning optional.jis wrote:I think the best solution would be to add a new item in Confirmations in Options for ADS Operations. Please, don't throw away some ADS and others not.
Sorry, but I don't think it's so important. At least for now, I won't add any similar option.jis wrote:So what about compromise: Add a new item in Confirmations in Options for ADS Operations, but for turning on/off ADS Loss warning only for known types? Isn't this better than silently ignore known ADS?
It's a pityPetr Solin wrote:Sorry, but I don't think it's so important. At least for now, I won't add any similar option.jis wrote:So what about compromise: Add a new item in Confirmations in Options for ADS Operations, but for turning on/off ADS Loss warning only for known types? Isn't this better than silently ignore known ADS?
But it's up to you. Maybe in the future
Do not blindly delete your ADS's!
Please do not blindly delete all your ADS's.
More and more programs are using them to store additional information. For instance Windows Mail (successor of Outlook Express in Windows Vista) will use them to store information about emails, that cannot be read from the email itself. (e.g.: flags, account the email was delivered to, read/unread state, ....)
