Problematic bzip2 package
Posted: 28 Nov 2018, 17:07
				Hello,
I've downloaded and entered https://github.com/git-for-windows/git/ ... it.tar.bz2, and copied all the directories out from the archive.
At first, It seemed to work as expected, and no error was indicated.
But after some time it was clear there are some files missing in the stuff copied out from it, for example the file mingw64/bin/git-upload-pack.exe.
I can see the file is present in the archive when inspecting the archive contents on Linux (tar -jv --list -f Git-2.19.1-64-bit.tar.bz2 | grep upload). But the file is just a link to another file in the compressed tar archive, as the command writes this:
See https://github.com/git-for-windows/git/issues/1904 for some more details.
It would be great if AS could handle such links, or at least create copy of the files (e.g. if the target FS does not support links).
Even if it cannot be implemented for some reason, it should at least indicate some error or warning.
$ tar -jv --list -f Git-2.19.1-64-bit.tar.bz2 | grep upload
hrwxr-xr-x ContainerAdministrator/380929       0 2018-10-04 23:35 mingw64/bin/git-upload-archive.exe link to mingw64/bin/git-receive-pack.exe
hrwxr-xr-x ContainerAdministrator/380929       0 2018-10-04 23:35 mingw64/bin/git-upload-pack.exe link to mingw64/bin/git-receive-pack.exe
hrwxr-xr-x ContainerAdministrator/380929       0 2018-10-04 23:35 mingw64/libexec/git-core/git-upload-archive.exe link to mingw64/bin/git-receive-pack.exe
hrwxr-xr-x ContainerAdministrator/380929       0 2018-10-04 23:35 mingw64/libexec/git-core/git-upload-pack.exe link to mingw64/bin/git-receive-pack.exe
-rw-r--r-- ContainerAdministrator/380929   34294 2018-10-04 23:35 mingw64/share/doc/git-doc/git-upload-archive.html
-rw-r--r-- ContainerAdministrator/380929   33379 2018-10-04 23:35 mingw64/share/doc/git-doc/git-upload-pack.html
