Translator: problem with selecting controls in layout editor
Posted: 24 Jul 2010, 20:04
Split from http://forum.altap.cz/viewtopic.php?f=23&t=3959
Note: It is possible to adjust this value using Microsoft Tweak UI utility. See the screenshot with the mouse page: http://articles.techrepublic.com.com/51 ... 54309.html for "Mouse sensitivity > Drag".
Regarding control resizing: select it and press the Shift+Left (Right) arrow to change the control width. This way you can resize all selected controls really fast. Does it work for you?
It is really strange. There is "dead zone" implemented when you left-click control. It will not move until you move your mouse for more than 4-5 pixels. The exact count of pixels comes from your Windows settings: GetSystemMetrics(SM_CXDRAG). What about Altap Salamander and drag&drop in panel? Does it also start immediately when you left-click the file name? What about drag&drop in Windows Explorer window?superBK wrote:The problem with the lay-out was if i use the mouse to select a button or textfield it will move far away autmatically. But if i click on undo in the menu the selected object will return back to its position and maintains selected, so by selecting multiple objects i need to cick on undo for every object. And i can only use the keyboard to move and make the objects longer. Don't know why this is happening.
