Can't import configuration file from 2.53 beta 2 to 2.53
Posted: 07 Jul 2010, 11:45
by Ewen Graham
I have exported the config file from 2.53 beta 2 to the directory where the 2.53 release candidate but when I run it it say it can't import the file (see attached). What am I doing wrong?
cheers,
Ewen
Re: Can't import configuration file from 2.53 beta 2 to 2.53
Posted: 07 Jul 2010, 17:19
by therube
The problem is basically what it says.
Your exported 2.53b2 registry file points to 2.53b2 entries, so something (similar I suppose) to this:
REGEDIT4
[HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.53 beta 2] ...
Now you're looking to import that configuration into 2.53 - & expecting the import to make changes to the tree naming (from 2.53b2 <or similar> to 2.53). So:
REGEDIT4
[HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.53] ...
But that import does not do that.
Though when you first install 2.53, on startup, it has the option to Import old configuration. It is at that point where it will both import & also revise the entries to accommodate the version change. So:
becomes
Or you could manually edit the exported .reg file, adjusting it so that instead of showing 2.53 beta 2, it shows 2.53.
%s/2.53 beta 2/2.53/g
Posted: 07 Jul 2010, 17:27
by Ewen Graham
Cheers that's fixed it! :D
