Page 1 of 2
				Setting of Altaptrl
				Posted: 04 Jul 2010, 14:35
				by ADB
				Hi
I just downloaded the set to translate Salamander into French.
But impossible to start "start makelang.js script in Automation plugin" from Salamander.
I've changed the directory in shell.reg, changes all, but still nothing.
How can I work?
Thks
ADB
				Re: Setting of Altaptrl
				Posted: 05 Jul 2010, 05:25
				Hi, I'm out of office. Will be able to help you from next monday.
Did you study the readme file that comes inside AltapTrl package? It is pretty detailed.
				Posted: 06 Jul 2010, 09:11
				by ADB
				Happy holidays
Yes, I did and I think that I did exactly what it is written.
I will be back of 15th...
ADB
				Posted: 06 Jul 2010, 22:07
				by Ether
				ADB wrote:But impossible to start "start makelang.js script in Automation plugin" from Salamander.
What is making it impossible? Tell us what exactly you do to start it.
				Posted: 01 Aug 2010, 20:07
				by ADB
				Hi
I just retried to launch makelang.js hrough Salamander. Still impossible!
Plugin Automation still has in grey the command Run focused script.
I don't know what to d (except to make all by hand)
Thks
Arnaud Dupin
				Posted: 01 Aug 2010, 20:14
				Hi, did you left click the makelang.js (so it is focused in the active panel) before you tried to run it using Automation plugin?
				Posted: 04 Aug 2010, 09:30
				by ADB
				For sure, yes.
ADB
				Posted: 04 Aug 2010, 14:16
				ADB wrote:For sure, yes.
ADB
It looks like you didn't install (extract/unpack)
Altap Translator package to your disk and you are trying to start .JS file directly from the altaptrl253a.7z archive. Could you please check your Altap Translator files path? Focused .JS file should be: C:\ALTAPTRL\Salamand 2.53\projects\makelang.js. Is it your case?
				Posted: 05 Aug 2010, 09:14
				by ADB
				Definitely yes. Excuse me but I am not really a rooky. I've tried many solutions, but still grey to launch. See the printscreen
				Posted: 05 Aug 2010, 09:24
				by ADB
				Better
				Posted: 05 Aug 2010, 10:54
				OK, in this case it must be
disabled Windows Script Host on your Windows or missing/disabled/unregistered JavaScript engine.
Please download prepared French projects from this post. Unpack it to C:\ALTAPTRL\Salamand 2.53a\projects
(the project path will be C:\ALTAPTRL\Salamand 2.53a\projects\french\salamand.atp)
The Salamand 2.53a comes from recently updated
Altap Translator.
				Posted: 05 Aug 2010, 11:13
				OT: I just found one small problem. You are not receiving email notifications from this forum.
They are bounced with following error message: Recipient address rejected: MailBox quota excedeed
				Posted: 18 Aug 2010, 18:35
				by ADB
I know, but did'nt find where to put my address now.
It is anyway: a[dot]adupinbe[at]orange[dot]fr
Thks
ADB
Edit: obfuscated email address to avoid excessive spam.
				Posted: 18 Aug 2010, 20:18
				by ADB
				Well, it works finally.
1) should I (re)install Java (where to find it anyway) to make works the js script and avoid to copy all english.slg to french.slg for each module?
2) why there is no Search&Replace function to replace any string by another ?
Thks
ADB
				Posted: 20 Aug 2010, 11:51
				by Petr Solin
				ADB wrote:I know, but did'nt find where to put my address now.
I have changed it for you. BTW, you can change it under Control Panel / Profile.
