Checksum plugin: Blocking files?
Posted: 25 May 2010, 02:10
by Eric
After using the checksum plugin (Verify) and closing it, it seems that a file handler stays opened.
I'm using it over a shared network folder, and it happens nearly everytimes (for larger files).
I checked it with process explorer and it shows a file handler (not closable).
AS 2.5.3 Beta2
Win 7 (64Bit) and Win2008R2 (64Bit)
Thanks
Eric
Re: Checksum plugin: Blocking files?
Posted: 25 May 2010, 08:34
by Jan Patera
Eric wrote:After using the checksum plugin (Verify) and closing it, it seems that a file handler stays opened.
Hi Eric,
I am unable to reproduce the problem. Did the verification finish before you closed the Verify window? Were there any errors reported during the Verification?
Posted: 25 May 2010, 12:06
by Eric
Jan Patera wrote:Hi Eric,
Hi Jan,
Yes, the verification was finished. I closed the plugin and then I tried to move the directory (where the files are) -> Error, file in use.
After the error, I checked the file handlers. One of the verified file was still open (in the process of AS).
After closing AS and restarting, I was able to move the directory.
Thanks
Eric
Posted: 25 May 2010, 12:15
Note: maybe the problem is not related to the Checksum plugin. It could be caused by any shell extension (third-party software component installed on your computer) loaded into AS process.
Posted: 25 May 2010, 13:55
by Eric
Yes, could be.
But there are not other process loaded into AS (process explorer would show it as child process), and the file is only locked by the AS process.
Thanks
Posted: 25 May 2010, 14:00
Shell extensions are hosted (running) in Windows Explorer (or Altap Salamander, etc.) process. Please see
http://www.altap.cz/salam_en/faulty_she ... sions.html
Posted: 25 May 2010, 17:08
by Eric
One of those I haven't installed.
I have TortoiseSVN, PowerArchiver, perhaps Snagit 10. So I can't tell.
Posted: 25 May 2010, 19:44
by therube
