Panel Row Focus Changes when Editing with VIM
Posted: 14 May 2010, 23:16
Panel Row Focus Changes when Editing the First File with VIM
... running out of time, so i'll ramble & come back to clean it up later ...
set focus to the FIRST filename in a panel
(make sure there is more the one file displaying in the panel)
panel sorted by time, most recent first
invoke Vim (gvim.exe) on that file
(by default?) Vim creates a new file in the directory, filename.swp (hidden attribute)
since *.swp is newly created, it then becomes the "first" filename
at that point, *.swp has focus in the panel
(make a change &) save & exit Vim (change & saving is important)
Vim closes
focus is now on the second filename in the panel rather then the original
... this may be a result of Vim re-creating the file (like a process that exits & recreates itself under the same name, but the PID is now different), & so may not be a Salamander issue per say?
Vim closes
