Salamander classic icon is back (almost)...
Duck
Post by Duck »
I really miss the old Salamander icon although it does look dated nowadays. I saw a much more polished classic salamander icon as one of the entries in that new icon competition. So I downloaded it, edited the colors to turn the white background to transparency, and converted it into a .ico file to use for short cuts. Here it is if anyone wants it...
classic icon.zip
(42.25 KiB) Downloaded 532 times
Problem is, in Windows 7, I can't use that icon when it is pinned to the task bar because when I launch salamander, the icon changes back to the orange foot thing icon.
In Salamander config, I see there is the option to change the color of the main window icon. Could you add another option to allow for external icons please?
Also, is it possible to add another option to completely change the main window title text? Because I want to change it to "Servant Salamander" >.<
Ok thanks, and really great program by the way.
Re: Salamander classic icon is back (almost)...
Thank you. Attaching your icon as PNG for others.
