Extremely slow start
Posted: 02 Apr 2010, 10:24
by Wolf
I added 10 programs to the "User menu" with a bad side effect. After I restart my PC, the first start of Salamander takes now between 30 and 60 seconds, I think that this is related to Microsoft Security Essentials.
Then I tried to replace the program icons with a dummy icon and the speed went back to normal. Seems that Salamander extracts the icons at startup what causes this delay because MSE verifies these EXE files.
I would suggest to save these icons in the registry, then Salamander and the startup speed is not dependent from icon extraction and a huge slow down caused by MSE.
Re: Extremely slow start
Posted: 02 Apr 2010, 12:34
by Ether
I wouldn't recommend saving any icons into the registry. Instead, the system icon cache should take care of it. Anyway, you should complain to Microsoft, too, as it is their product that caused the slowdown.
Posted: 02 Apr 2010, 14:05
by Wolf
why not?
I already did this months ago since we had the same problem with our own applications. Our customers complained and now we use our own icon cache what fully fixes that problem. Also other virus scanners can cause such a slow down.
Posted: 04 Apr 2010, 02:19
by Ether
Wolf wrote:why not?
Because Windows registry is not suitable for saving binary data. And because Windows has a built-in icon cache ('the Shell normally attempts to load the icon from its cache', from
MSDN: Creating Icon Handlers; I couldn't find anything more informative).
Posted: 04 Apr 2010, 10:44
by Wolf
You can save it everywhere you want, even in the registry, Icons converted to B64 are not that large. I just wanted to point out a bottleneck, not a strong request to save it at a certain place. The registry was just an example because Sal stores many things in the registry, but you can also use XML, single files or whatsoever. And you must not mention the icon cache again, you already did it twice. We are now aware of that, but technical decisions should be made by the experts of Altap.
I know how to avoid it here on my PC to reduce a starting time from 60 seconds to 1-2 seconds, I just posted that such a slow down can happen for MSE users.
Posted: 04 Apr 2010, 13:43
I hope MS will fix this problem. Thank you for reporting it.
