split plugin UI not consistent on 2.53 beta 1
Posted: 17 Mar 2010, 09:23
I tried to split the 156,072,883 bytes file by select number of parts: 9 then the size of each part show as 17,341,432 (in grey) but then when I change the selection on each part show I must type in 17341432 (without comma) so this a little bit confusing.
can you make it more consistent tho show the bytes value format when we switch between the size of each part and number of parts?
