PB 44: Automation script and PowerShell
Posted: 07 Mar 2010, 20:18
by Eric
Will PowerShell as scripting host be supported?
Mapping the .ps1 extension to PowerShell.exe will not be enough.
Thanks
Eric
Re: PB 44: Automation script and PowerShell
Posted: 07 Mar 2010, 20:49
Eric, there are no such plans right now.
Posted: 07 Mar 2010, 21:04
by Eric
Jan, would be great if you could add it.
All the objects should be supported out of the box.
Eric
