Packed column should provide more relevant data
Forum rules
Packed column should provide more relevant information.
For instance, packed shows the packed size of the singular file, which happens to be highly irrelevant in this case.
Re: Packed column should provide more relevant data
therube wrote:Packed column should provide more relevant information.
And what else should be there?
Well, that's the thing. I'm just not sure?
Given the multiple & varying ways that the data is presented as it is (by various utilities, command-line & GUI), perhaps an overall summary, or if not that, then the ability to "flatten" the listing? Or present it as it is with an option key to flatten or present an overall summary?
http://therube.pastebin.com/yBeD29uB
http://therube.pastebin.com/LFwwepYY
http://therube.pastebin.com/0ZGVB06t
http://therube.pastebin.com/eV84Q3ET
http://therube.pastebin.com/tczDKQhZ
Or when you spacebar on the subdirectories, at the same time obtain & present the packed size of same.
therube wrote:Given the multiple & varying ways that the data is presented as it is (by various utilities, command-line & GUI), perhaps an overall summary, or if not that, then the ability to "flatten" the listing? Or when you spacebar on the subdirectories, at the same time obtain & present the packed size of same.
Aha! So, you want:
a) additional columns
b) packed size of directories
See my revised post (picture) above.
