Batch rename: add "keep extension"
Posted: 12 Feb 2010, 10:46
Once in a while I use AS batch rename to... well, rename files. Most often I use counter to get consecutive numbers. I think it'd be great if default for "Start at" was 1, not 0 (this could go to "Options", though), but that's not my point. My point is that after adding counter I need to click on the "New name" field twice (to focus on it and then to undo selection) and fill in extension, which in my case is always the same as original. Hence my request to add to the "Add Counter" settings window yet another option: "do not change extension", preferably checked by default. (I do not use other options for renaming files. Perhaps it'd be more appropriate to solve my little problem in some other way, i.e. add this option somewhere else; that's fine with me.)
