Really a useful feature should be to keep in memory the screen capture program.
It's a little bit annoying when you need multiple captures.
Thanks a lot for this excelent file manager.
Plugin - Pictview - Screen Capture
Re: Plugin - Pictview - Screen Capture
You can access the capture functionality from the Plugins/PictView/Screen Capture menu within Salamander main window. You can use just Ctrl-I for repeated use of the same command from the Plugins menu.Margodth wrote:Really a useful feature should be to keep in memory the screen capture program.
With this, you can have as many captured screens displayed as you wish.
Is this what you want to achieve?
