Right click drag-n-drop move with Subversions files
Posted: 27 Jan 2010, 16:08
by pederalm
Hi
If you are trying to move Subversion revision controlled files in Windows Explorer, using mouse right click drag-n-drop, you get a menu with 8 options (see Clipboard01.jpg). If you are doing the same move operation in Altap Salamander you only get 4 options in the menu (see Clipboard02.jpg). I find this to be a bug.
Re: Right click drag-n-drop move with Subversions files
Posted: 27 Jan 2010, 16:12
Thank you for this bug report. We can reproduce it but (probably) will not be able to fix it due to Windows drag&drop implementation.
Please update to final version 2.52.
Posted: 28 Jan 2010, 01:53
by zarevak
Heh?
I'm able to use SVN commands after clicking the "Other..." item in the menu. I'm not sure, why it needs an extra click, but it worked for me for a long time ;)
Posted: 08 Feb 2010, 10:47
by pederalm
Thanks! I have never tried the "Other" menu option, but it works :D
I wonder why the first menu doesn't show the SVN-menu options instead of the "Other" menu. Strange....
Posted: 08 Feb 2010, 10:58
It's limitation of current implementation. It could be solved using shell extension that Salamander already has. We have this task on our todo list.
