Customizable shortcuts
camper
Post by camper »
I'd like to have customizeable shortcuts. I don't care whether it needs messing in a text file as long as I can change certain default shortcuts.
E.g. I want to be able to use cursor-left (or backspace) to go one directory level up or cursor-right (or enter) to dive into a directory.
Re: Customizable shortcuts
Excuse me, are you joking?
Backpace and Enter key do what you are talking about. Exit or enter directory.
These are the oldest keyboard functions in Salamander.
Alt+ arrow left/right move through the history of visited folders.
You should really read the help. Press F1 in Salamander, go to Shortcuts > Keyboard shortcuts and learn about all of them.
camper
Post by camper »
Of course do Backspace and Enter work - that's what I'm using since ages. But I'd like to add "Lynx-like motion" (for those who know Midnight Commander from Linux/OS X) where you can use the Cursor-Left and Cursor-Right keys to go one level up or down.
