Page 1 of 2
Delay after every file operation
Posted: 17 Dec 2009, 13:53
by Tim
Dear Forum!
Using Salamander 2.52, I experience a delay of about 1 s after every file operation (copy, move, etc.).
This delay acts like a brake that prevents me from using Salamander within this 1 s.
The program just does not react.
The behaviour is the same on local and remote drives.
How can I get rid of this delay?
It really dampens my productivity.
Am I missing something fundamental?
Thanks for any help in advance
Tim
Re: Delay after every file operation
Posted: 17 Dec 2009, 14:00
by Raptor
Maybe antivirus related problem?
Posted: 17 Dec 2009, 14:04
Tim, what about operations such as View File or Change Attributes?
Please try to disable Options > Configuration > Icon Overlays > Display custom icon overlays option.
by Tim
Thanks for your input, Raptor.
Tested turning off ESET.
No change in behaviour.
Unfortunately, it must be something else.
Cheers
Tim
Posted: 17 Dec 2009, 14:05
Has already been reported HERE
Posted: 17 Dec 2009, 14:07
by Tim
SelfMan wrote:Has already been reported HERE
Thanks for telling me.
Reported, but not solved.
Cheers
Tim
Posted: 17 Dec 2009, 14:09
by Tim
Jan Rysavy wrote:Tim, what about operations such as View File or Change Attributes?
Thanks, Jan.
OK, turned it off.
Now, the delay seems even longer.
What's going on here ... ?
A similar problem has been discussed HERE
Just search for delay or lag as keywords.
Posted: 17 Dec 2009, 14:10
Thanks, Jan.
OK, turned it off.
Have you restarted salamander after the configuration change?
Posted: 17 Dec 2009, 14:11
Tim, your first posts are from 2006. Did you notice these delays before AS 2.52?
Or, does it start with installation of AS 2.52?
Posted: 17 Dec 2009, 14:13
SelfMan wrote:A similar problem has been discussed HERE
And here http://forum.altap.cz/viewtopic.php?f=2&t=3053
Posted: 17 Dec 2009, 14:14
by Tim
Thanks, Jan.
OK, turned it off.
Yes!
Posted: 17 Dec 2009, 14:15
by Tim
Jan Rysavy wrote:Tim, your first posts are from 2006. Did you notice these delays before AS 2.52?
Not sure, but I guess it started with 2.52 (Beta).
Posted: 17 Dec 2009, 14:19
What OS are you on? Which version of ESET Antivirus/ESS do you have?
Are you using any programs with shell extensions like TortoiseCVS/SVN?
Could you please test older versions? (Install it to some temporary directory.)
AS 2.51: ftp://ftp.altap.cz/pub/altap/salamand/as251.exe
AS 2.5: ftp://ftp.altap.cz/pub/altap/salamand/as25.exe
