bzip2 support in ZIP
Posted: 10 Feb 2006, 10:22
by firelizard
Hello!
Would you please consider adding support for reading .zip files created with bzip2 compression method, which can be created by latest WinZip and 7-Zip.
Thank you!
P.S. Salamander is the best! :hurray:
RE: bzip2 support in ZIP
Posted: 10 Feb 2006, 11:16
Is the specification of this new ZIP compression method available?
Posted: 10 Feb 2006, 11:31
by Guest
Yes, you can find it here at
bzip.org. Currently Salamander opens bzip2 .zip files for listing only, and I was even able to read some tiny .gif and .jpg files from such an archive, but it would be best to have full support for this! Thank you!
Re: bzip2 support in ZIP
Posted: 26 Feb 2010, 11:07
ZIP archive with bzip2 compression again, after 4 years:
http://forum.altap.cz/viewtopic.php?f=6&t=3827 (Wallpaper1b.zip attachment).
Posted: 28 Feb 2010, 11:03
by Jan Patera
firelizard wrote:Would you please consider adding support for reading .zip files created with bzip2 compression method, which can be created by latest WinZip and 7-Zip.
Such obscure archives can be extracted with the next version of Altap Salamander (AS 2.53b1/2.53).
