Corrupted "Panel Font"
Posted: 09 Nov 2009, 13:53
Today, while using Salamander as usual, I suddenly noticed strange things happening.
First, I thought my keys were not working in Salamander. But a closer look showed, that the screen was just not updated completely.
I restarted Salamander to see if that helped. But sadly, it became much worse, in that every line suddenly filled a large part of the screen!
After comparing the registry entries with a saved configuration, it turned out that the entry "Panel Font" was corrupted. It contained the value: "en Bosch.doc,1764584545,1766072423,115,105,99,116,32,68", instead of "Fixedsys,-12,400,0,0,1,2,1,49".
The start of the string is the last part of a filename I worked with.
I recollected some memory about the exact same behavior, and I found out that it happened to me once before, on 16-10-2003 with some beta 9. The value then was "Fixedsys,807412332,540028960,34,0,1,2,1,49" (named "Basic Font" in that version).
I am afraid I will not be able to reproduce this strange situation.
