Like the "Name:" field the "Look in:" field needs an excluding mask after a vertical line character,
e.g. "|System Volume Information;$RECYCLE.BIN;recycler;NotMyDir".
The "Found Items" list has no deduplication function like "mark all duplicates except one" for easy deleting all duplicate files.
Deduplication option could be:
- Keep younger / older files and/or
- keep all files from same tree
Improving Find (duplicate) Files
Re: Improving Find (duplicate) Files
Try Options > Ignore Directory List... in the Find window.andydelor wrote:Like the "Name:" field the "Look in:" field needs an excluding mask after a vertical line character,
Ok, "|System Volume Information;$RECYCLE.BIN;recycler;NotMyDir" was a bad example.
The Ignore Directory List is fine but inflexible and the excluding syntax for "Named" will be finer at this point.
Same request: I would perform the following:
1) Move probable duplicate directories to their own drive 2
2) Compare drive 1 with drive 2, ignoring name (size+content)
3) Sort the found list by directory
4) Use the shift + down arrow to mark the duplicates
4) Del key to erase into the recycle bin
5) Check recycle to verify that all is ok
---- I currently use the compare pane with dir 1 on the left and
dir 2 on the right. However, unless the directories have the
exact same name and the exact same files, I need to go to
each and every subdirectory on its own. Compare. Delete dupes.
This is VERY time consuming if there is a complex directory tree.
Your found list handles the entire drive and all its subdirectories
and the list is great. Just need a quick way to delete.
THANKS
THANKS
