Windows 7 - folder icons and context menu
Posted: 01 Sep 2009, 12:19
Im have installed Salamander on Windows 7 and I want to use TortoiseSVN. If I use windows explorer everything works normal. Folder icons have that small icon from SVN in it and when I open context menu I can find all posible options and buttons for SVN. But if I use salamander then there are no icons from svn and there is no SVN in context menu.
Can this be repaired?
