Version 0.0.10 (12.09.2009)
- missing contextmenu functionality for "delete" service - fixed
* "service is marked for deletion" errormessage
Version 0.0.9 (11.09.2009)
+ F8/DEL | FS_SERVICE_DELETE implemented
* "delete service" function moved from properties dialog to contextmenu
- if two service panels were active only the active panel was refreshed on a state change - fixed
Version 0.0.8 (08.09.2009)
+ new "delete service" function (use with caution!)
* changed tab order
* Servicename is now selectable
Version 0.0.7 (08.09.2009)
* new default context menu entry "Properties"
Version 0.0.6 (08.09.2009)
+ changing the startupmode is now supported
* RTL is now statically linked
Version 0.0.5 (07.09.2009)
+ new "Info" dialog
+ moved all strings to the lanugage dll
* removed the extension column
* doesn't need admin privileges anymore (at least for listing)
- numerous smaller bugfixes (icons, infolinecontent,..)
Version 0.0.4 (29.08.2009)
+ new contextmenu entry "Open Service Control Manager"
- invalid string in the information line when selecting multiple files (@Jan)
- removed (hopefully) all debugmessages
Version 0.0.3 (28.08.2009)
+ integrated contextmenu functionality for start/stop/restart services
* changed filesystemname from "srv" to "svc"
* changed plugin directory from "SrvExp" to "svcexp"
Version 0.0.2 (28.08.2009)
- fixed a debug "Error" message in the "About" dialog (thx @thomas)
Version 0.0.1 (28.08.2009)
First public release.
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
By testing on Vista I found, that when your AS is not running as Admin, you won't get any detail information. This is understandable - you should only take this into account when displaying the information - it shows some wrong values.
In the future I would expect that double clicking the service would open the Service properties...
Any chance to set up detailed view as default for this plugin?
Sorry guys, I don't want to downplay the work done on this. Its great, but isnt ProcessExplorerfom SysInternals a better options for handling this stuff? You can even replace the Task Manager, so CTRL+SHIFT+ESC and pop you have Process Explorer running.
SelfMan wrote:Sorry guys, I don't want to downplay the work done on this. Its great, but isnt ProcessExplorerfom SysInternals a better options for handling this stuff? You can even replace the Task Manager, so CTRL+SHIFT+ESC and pop you have Process Explorer running.
Sure, there are many AS plugins/functions that could be replaced by better alternatives. But for me, I would use this plugin. I only need to check if the service is runnig, start, stop or see properties. Even the creation of file list from selected services by AS (Ctrl-M) is useful for me. It is more comfortable for me to see this inside AS with my configured colors then start new different looking window.
Let us suprise what functionality Mike could add...
@Petr:
Thanks for clarification on column sorting.
The SDK is quite readable with the help of Google Translate.
@thomas:
Thanks for your feedback. This is fixed in the updated version (0.0.2).
@martins:
Thanks for reporting. I will look into this.
Actually this plugin is planned as "Windows Service Explorer" only so killing/listing processes is beyond scope of this plugin.
Nevertheless i will try to implement parts of the wishlist from Joakim Skoglund http://forum.altap.cz/viewtopic.php?f=14&t=2700 after
this plugin is finished and functional. So a "Process Explorer" is something which is proably on the "roadmap".
I like better quick search support in Salamander panel, option to change items order using familiar keyboard shortcut. Also chance to bookmark path for example in Windows Registry, etc.
@mike12345, thanks for the fast bug fixing. Sorry, that I'm so fussy but there is a problem with the context menu.
Some plugins has a context menu, if not then this function is disabled. But your plugin opens a unnecessary information dialog.
the contextmenu is currently disabled because the functionality in this version is not implemented yet.
This is the part I'm currently working on. The next version will enable the menu's. Stay tuned.
Some small issues: while selecting multiple items in panel, the invalid string is displayed in Information Line:
When your plugin is active in panel and some file is created on disk, the following message box is displayed:
The Properties item from context menu doesn't work on my system (Windows XP). Could you also open this
dialog on Enter, as standard Windows Services windows does?
Version 0.0.4 (29.04.2009)
Salamander 2.5.2
errr, seems like it's broken. (all columns display boot and or nonsense)
furthermore, all of the rh mouse button context menu is grayed out
