File Comparator additional functions
thomas
Post by thomas »
I miss an edit and search function for the file comparator. Why you are comparing files? I use it to looking for differences and editing files. For example: comparing translation files
Re: File Comparator additional functions
Hi Thomas, you are looking for merge instead of compare. Try http://winmerge.org/
thomas
Post by thomas »
I believe, that I need a tutorial for intergrating winmerge in the Salamander. So that I can use it like the "file comparator". :? Probably I will found some information here in the forum. I'm sure. :wink:
Yes, you can use the Search function for "WinMerge".
You will find for example http://forum.altap.cz/viewtopic.php?p=16356#p16356
