Check for new version
docfxit
Post by docfxit »
When I run the plugin "Check for new version"
I get an error saying:
connecting failed: An error occurred in the secure channel support
I'm currently running Salamander ver. 3.08 x86
in XP
Do you have any idea how I can fix it?
Thank you,
Docfxit
Re: Check for new version
Maybe replacing the old OpenSSL?
https://forum.altap.cz/viewtopic.php?f=10&p=58503#p58503
I get the same - on XP.
And I believe its going to be (primarily) an XP issue.
In this case, I believe it going to be something like Salamander is relying on OS features in order to negotiate the SSL connection, & XP does not have the built-in (cipher) support needed.
Now, suppose it is also possible that Salamander could supply the "bits" needed outside of what the OS provides, in which case the connection would work... (But given that XP is EOL <well, kind of ;-)>, including EOL to Salamander, its kind of a moot point.)
Similarly in my download manager, Net Transport, which at this point is old, many times I'm unable to connect to SSL sites - some, not all, suppose it depends on how the site is configured, & I'll get messages like:
URL: https://github.com/avih/dejsonlz4/relea ... 4.v1.1.zip
06/30/2017 11:28:39 AM.828 The supplied message is incomplete.  The signature was not verified.
At those times, I'll just jump to WGET (or through my browser), which works.
WGET.exe  https://github.com/avih/dejsonlz4/releases/download/v1.1/dejsonlz4.v1.1.zip
This hints at TLS 1.2, which is an unknown entity to XP.
FIX: "The supplied message is incomplete" error when you use an FTPS client to upload a file in Windows
Support for SSL/TLS protocols on Windows
https://www.google.com/search?q=XP+The+ ... unofficial
XP, IE8 (cough), only talks about TLS 1.0.
