We prepared test version of the Automation plugin that fixes issues with running Ruby scripts (as discussed in the Czech part of the forum). Although very unlikely this change may break scripts in languages other than Ruby. All Automation plugin users are urged to test their scripts (whatever language they use) with the fixed version of the plugin. Please report issues here before the fix will make it into the next scheduled release of the Altap Salamander.
Thank you.
Out-of-band Automation plugin release
manison
- automation_v1.7.7z
- (120.26 KiB) Downloaded 4779 times
