Hi -
I just noticed the word DROPFAKE on my taskbar today (screen grab) under Windows XP Pro SP3. It still appears after a reboot. I did a Google search for 'dropfake' and 'dropfake taskbar' and only came up with one hit on the Altap forum: http://forum.altap.cz/viewtopic.php?f=2&t=1408 which doesn't correspond to what I observe. But for that search result I wouldn't have suspected Servant Salamander could be involved, but it's all I have to go on. Clicking, double clicking and hovering the mouse above the word does nothing. I am baffled. Does anybody else have any clues? I am using Salamander version 2.52 beta 1. Thanks
DROPFAKE on taskbar
DROPFAKE on taskbar
- taskbar with DROPFAKE
- dropfakejpg.jpg (7.07 KiB) Viewed 9771 times
Re: DROPFAKE on taskbar
Sorry for troubles! To remove this "toolbar" just right click it and choose Toolbars submenu and click on DROPFAKE item.
This happens when you drag&drop files from archive or filesystem (from Salamander) to taskbar. DROPFAKE is just an empty directory placed in TEMP directory, it is used to get the target path of drag&drop operation and when it fails (e.g. this case with taskbar), it is unintentionally moved/copied (Salamander displays messagebox with warning that it could happened).
Petr -
Thanks for the quick and complete answer to my question including the event that resulted in DROPFAKE on taskbar. My minor problem was solved with your help and I learned a bit more about the taskbar as well. I apologize to take so long to thank you for your help.
Hugh
Hugh
