Servant Salamander v1.52
vld
Post by vld »
I'm looking for a small 2 pane file manager for a thmb-drive to be used in when fixing a pc. Seems like Servant Salamander v1.52 will do the job. I seen that applications can be added, though the user menu is hidden and not easily visible.
Is there a way to add a plugin like 7z or winrar just to uncompress files?
Is there a way to make the user menu visible?
Re: Servant Salamander v1.52
I am sorry, but I believe that version is no longer supported. Do not expect any work regarding enhancements and features on the (really) old version.
You might check this http://forum.altap.cz//viewtopic.php?f= ... 84&p=14625
For othe references search for the word "portable"...
vld
Post by vld »
I know it's an outdated version and there is enough talent on this board that someone may have done it or knows how to do it. I don't know what the link you gave me refers to, but I am not looking for a portable salamander, I want to see if 152 can be tweaked,
vld wrote:Is there a way to add a plugin like 7z or winrar just to uncompress files?
7-Zip and WinRAR, as stand-alone applications, both offer context menu items for uncompressing (and the operation runs on background as a bonus). Or use portable versions of them, if it helps.
KNUT
Post by KNUT »
vld wrote:Is there a way to make the user menu visible?
F9
Kind regards, KNUT
