unable to open new 7z format with LZMA2
Since 7-Zip 9.0 alpha version, a new compression algorythm is available: LZMA2.
Useless to say that the new archives are incompatible with 2.52ß1 version.
Is it a big problem to get an updated version?
Re: unable to open new 7z format
7z 9.0 alpha was released only this week. In general, alpha usually means not yet stable.amministra2000srl wrote:Since 7-Zip 9.0 alpha version, a new compression algorythm is available: LZMA2.
Until very recently (actually at least until 9.0 alpha was released), it was not recommended to use LZMA2 in production environment because it was not finished yet and it was possible that files created then would be uncompressable with the next build. We will evaluate the situation and inform you here on the forum.
I did not consider that. Thanks for your advice and, please, keep on the good jobJan Patera wrote:it was possible that files created then would be uncompressable with the next build.
I just noticed this text in the release notes for 9.01 alpha:amministra2000srl wrote:I did not consider that. Thanks for your advice and, please, keep on the good jobJan Patera wrote:it was possible that files created then would be uncompressable with the next build.
Igor Pavlov wrote:Don't use this alpha version for important data. Call "Test" command after each compressing operation.
Now that 7 Zip has reached 9.04ß, could you please implement the new algorythm to make us test it?
Even a private beta version could be glad
For now you are asking alone. Let's wait until we will see more requests or final version 9.
The new LZMA2 has several advantages, e.g. faster decompression and better multithreading support (support for splitting work to chunks). But I rather wait for a final version/specification too, before use it for my own data.
Hi there,
for your own trials download
http://puzzle.dl.sourceforge.net/source ... 4_extra.7z
extract 7za.dll and overwrite with it the one in plugins\7zip.
PS: The same procedure e.g. with unrar.dll (newer version under: http://www.rarlab.com/rar/UnRARDLL.exe)
I tried with the previous version but did not work. Now it does, thanks for the news.EvaEden~ wrote:for your own trials download
The release notes still claim:amministra2000srl wrote:Now that 7 Zip has reached 9.04ß, could you please implement the new algorithm to make us test it?
Because there are also other interesting new features introduced in version 9 that we would like to adopt, we monitor the situation.Igor Pavlov wrote: Don't use this beta version for important data. Call "Test" command after each compressing operation.
Re: unable to open new 7z format with LZMA2
Although still in beta, this disclaimer is no longer appended to release notes. The next version of Salamander (2.53b1/2.53) will be capable of extracting 7z archives with LZMA2.Jan Patera wrote:The release notes still claim:Because there are also other interesting new features introduced in version 9 that we would like to adopt, we monitor the situation.Igor Pavlov wrote: Don't use this beta version for important data. Call "Test" command after each compressing operation.
However, we will add compressing with LZMA2 when the underlaying 7za library leaves the beta status.
