Mapped network drives loses connection
Posted: 08 Apr 2009, 21:02
by ChronoDK
I'm having a problem with my mapped network drives in Windows 7 x64. I map them at logon using "net use b: \\server\share /persistent:no /user:me pass" and this works fine to begin with. But if the connection is inactive for a while, they suddenly lose connection in Salamander 2.52. If I open Explorer there is no problem, and if I go back into Salamander the problem is gone. But having to start Explorer to enable the drive again is annoying. I don't do anything in Explorer - I just browse the drive and it works. The message I get from Salamander when the drive loses connection is "Drive Select Error - There is no disc in drive B. Insert a disc and then try again.". Makes no sense to me.
I tried using a VBscript to logon with, but there is no change. The same with a PowerShell script - it still loses connection after a while.
Re: Mapped network drives loses connection
Posted: 08 Apr 2009, 21:27
by zarevak
Can you try using another drive letter then A: or B:?
A: and B: drive letters were used for floppy disk drives and some applications handle these drive letters in special way. Salamander may be one of them.
Posted: 08 Apr 2009, 21:47
by ChronoDK
It's the same problem with my other mapped drives: M, P, S, V and W.
Posted: 08 Apr 2009, 23:44
Are all the mapped drives from the same server?
Verify the following registry key on the server machine.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters]
"autodisconnect"=dword:0000000f
autodisconnect - the idle time disconnect in minutes (15 default)
You might be interested in this KB article: "Mapped Drive Connection to Network Share May Be Lost"
Posted: 09 Apr 2009, 10:58
by ChronoDK
The server is a linux box, but it does put its harddrives into sleep mode after a while of idle time. They wake up once a connection is attempted though.
Posted: 09 Apr 2009, 11:01
by ChronoDK
The problem might not be Salamander-related though. My music player, foobar2000, can't figure out how to enable the connection either. It gives me a similar error until I start Explorer. So perhaps 32-bit applications just can't reconnect to mapped drives in Windows 7 64-bit.
Posted: 09 Apr 2009, 11:21
What about the standard (Windows) command line copy command? Does it reconnect as Explorer?
Posted: 09 Apr 2009, 18:50
by ChronoDK
cmd.exe works fine. Starting cmd and entering "b:" finds the drive and reconnects it such that Salamander has it available again.
Posted: 12 Apr 2009, 14:50
by ChronoDK
Still no solution to this problem?
Posted: 12 Apr 2009, 15:07
It looks like you are only person reporting this problem (probably caused by your Samba linux box), so it has low priority for us. I'm sorry.
Please see http://forum.altap.cz/viewtopic.php?f=2&t=3103 for more information...
Posted: 13 Apr 2009, 07:10
by vld
Does WXP have the same problem as W7?
Posted: 13 Apr 2009, 08:40
by ChronoDK
No. Salamander works fine in Vista and XP 32-bit.
Posted: 20 Aug 2010, 21:27
by ctimjones
Well you're not the ONLY one who experiences a loss of connection. I recently upgraded to Windows 7 Pro (64-bit). I'm using Servant Salamander 2.53 (Evaluation). I have a SAMBA share to my home directory on a CentOS 5 Linux server. When I copy large files (40MB + so far), the copy starts, but then hangs. When I use Windows Explorer, I have NO problems copying the larger files.
I was previously using Windows XP Pro with Servant Salamander 1.65 (Beta). Copying files from the Win XP Pro machine to the same CentOS 5 Linux server had NO PROBLEMS at all.
I see this thread is a bit old, so I'll keep searching to see if there is a solution. Just wanted folks to know others are experiencing this same issue.
Not sure if any of the following log info will be of help, but this is all I can find on the Linux server:
/var/log/messages
Aug 20 15:24:34 acer smbd[2206]: [2010/08/20 15:24:34, 0] lib/util_sock.c:read_data(534)
Aug 20 15:24:34 acer smbd[2206]: read_data: read failure for 4 bytes to client 10.1.1.157. Error = Connection reset by peer
smbd.log
[2010/08/20 15:13:39, 1] smbd/service.c:make_connection_snum(1033)
tjones-win7pc (10.1.1.157) connect to service public initially as user ctjones (uid=500, gid=500) (pid 2206)
[2010/08/20 15:13:52, 1] smbd/service.c:close_cnum(1230)
tjones-win7pc (10.1.1.157) closed connection to service public
[2010/08/20 15:24:34, 1] smbd/service.c:close_cnum(1230)
tjones-win7pc (10.1.1.157) closed connection to service ctjones
[2010/08/20 15:24:34, 1] smbd/service.c:make_connection_snum(1033)
tjones-win7pc (10.1.1.157) connect to service ctjones initially as user ctjones (uid=500, gid=500) (pid 2310)
Posted: 13 Sep 2010, 19:01
by Emphyrio
I experienced two problems with my network connections: 1) network file copying was slowing down to a crawl then disconnecting in Win7; 2) Altap Salamander can't see the other networked PC, while Windows Explorer connects to it just fine.
Problem 1 I solved with some registry changes, it was related to Windows 7. Perhaps someone can profit, like me, from the suggestions named in this article and its comments: http://www.windowsreference.com/windows ... mpression/
Problem 2 I still have. Altap Salamander is unable to connect to the other PC's shares. Salamander shows a popup with error 67: unable to locate network name. This error also occurs when I try to connect using the IP address. Windows Explorer works just fine, so I have to use that to copy my files now. Just wanted to chime in as the second Salamander user with this problem.
Posted: 14 Sep 2010, 05:52
by therube
1) LOL
Microsoft started off being sh-t and over the decades everything they do just gets more and more crap.
In another 10 years we won’t need to buy a new operating system, all we’ll need to do is sh-t on a hard disk to get the same result.
The best way to optimise Windows is to disable every feature, every security patch and every program written by a Microsoft programmer.
Inside every Windows computer is a geriatric old man with altzimers a pencil and a piece of paper.
2) no idea about the issue, but this seems to have some sensible ideas:
"No network provider accepted the given network path
System error 67 has occurred
The network name cannot be found"
http://www.chicagotech.net/troubleshoot ... rror67.htm
1a) Come to think of it, I put a 10 cent USB wireless adapter on a desktop. Only thing that concerned me was that there was some sort of connectivity - that something worked. Wasn't concerned about speed or anything like that. If it saw the Internet & saw the LAN I was happy. Thinking (though don't recall at this point) that it was a mule that I put W7 on to. Internet speed seemed fine. Though copying an ISO (~600 MB) was painfully slow. Could have copied it to a Flash drive, then back off much quicker then over the LAN.
I'll have to remember this the next time I get to experimenting. (Believe I have XP on there now, so might be interesting ...)
