Make slected row hightlight full panel width
MaxA
Post by MaxA »
Hello,
Can you prologn the selected row highlight till the end of the panel and make in full panel width. The empty space looks not too fine IMHO.
Not high proriority issue of course :)
Regards, Max
Re: Make slected row hightlight full panel width
(Ah, Configuration | Colors. Never visited that before. Which particular setting gave you the yellow highlight?)
thomas
Post by thomas »
@therube
Configuration/Appearance -> "Highlight focuse row" (Detailed modes only)
Configuration/Color/Items in panel -> "Highlighted part of row" -> Custom color of background...
Thanks.
Salamander Highlight Focused Row.png (15.13 KiB) Viewed 23090 times
I would like to +1 this request with an amendment: make the whole row also respond to clicks (to focus the item etc.). Otherwise there's sometimes not too much space to click on.
(Maybe there should be a narrow margin on the right so that the current directory's context menu is available.)
Of course only when Full row select is on.
