Thank You.
Thank You.
Thank You :-).
(Putting it here since you locked the announcement thread before I could get my post in there ;-).)
Re: Thank You.
Yes, announcements are locked by forum settings. Thank you.
Some points from Czech thread http://forum.altap.cz/viewtopic.php?f=8&t=32522
AS 3.07 was primarily bug-fix/maintenance release, next version will be feature release. Our current plans are:
Switch to Visual Studio 2013, clean source code from Windows 2000, XP, and Vista code paths.
Continue work on High-DPI support (based on SVG icons and graphics).
Work on UAC and Unicode support.
Investigate implementation of parallel copy/move/delete commands on network. From our internal tests it looks like we will be able to speed up Altap Salamander network operations.
EDIT: Look at support for Tabs - http://forum.altap.cz/viewtopic.php?t=6002
Re: Thank You.
Not that I have any clue about such things, so just a FWIW, on the Mozilla end, Bug 1186064 - Drop support for building with Visual Studio 2013.
WaldemarH
Re: Thank You.
Post by WaldemarH »
Yes thank you for the new release and looking forward for the WinSCP 64bit version (hopefully Martin will upgrade it).. it's the only reason I still have 32bit version installed.
