Avast virus message at 3.07 installation
Toepfe
Post by Toepfe »
Hi everybody,
I tried to install the new version 3.07 of Altap Salamander (32bit) and Avast Antivirus seems to find win32:evo-gen [Susp] in the file salspawn.exe. Is this a false alarm?
Any help is welcome ;-)
Bye
Heimo
Re: Avast virus message at 3.07 installation
Toepfe
Post by Toepfe »
Thanks for the quick answer :D
KNUT
Post by KNUT »
We've McAfee in our company. I'm afraid to install AS 3.07, because of the likelihood of a virus alert (That will result in an arrest of my computer! :shock: ).
Are there any experiences with McAfee? :idea:
Kind regards, KNUT
If you downloaded the file from Altap, its safe to install.
KNUT
Post by KNUT »
SelfMan wrote:If you downloaded the file from Altap, its safe to install.
safe and no virus alert?
Kind regards, KNUT
It is OK, no virus, no warning - I just did a new check with www.virustotal.com.
