Find Files List
rharding
Find Files List
Post by rharding »
The Find Files and Directories returns a list of all files that meet specified criteria. Is there a means of using the results of this command to perform tasks such as copying the selected files to another directory or zipping the files?
Thank you.
Richard
Re: Find Files List
Select those you want...
Copy, then paste elsewhere.
I'd think most anything available on a context-menu, open-with, send-to would work too.
May run into issues if you have too many selected (as in won't be able to pass XX number of names to a particular application, kind of thing)?
rharding
Re: Find Files List
Post by rharding »
<<May run into issues if you have too many selected (as in won't be able to pass XX number of names to a particular application, kind of thing)>>
This was the problem. The message is displayed in Salamander that "some selected file or directory is not available" if a "large" number of files are selected.
Thank you
Richard
