Unicode Support
KNUT
Re: Unicode Support
Post by KNUT » 31 Jul 2017, 16:00
omega wrote:Any update Jan?
Any update Jan?
Kind regards, KNUT
crystalidea
Re: Unicode Support
Post by crystalidea » 04 Aug 2017, 10:32
Yes, please, any update. Is the project alive actually? It's been a while (>5 years) since you promised Unicode.
omega
Re: Unicode Support
Post by omega » 05 Aug 2017, 15:28
crystalidea wrote:Yes, please, any update. Is the project alive actually? It's been a while (>5 years) since you promised Unicode.
Holiday season, must be out of office :D
Re: Unicode Support
Post by AD7 » 05 Aug 2017, 16:19
For critical case of Unicode need I use Notepad++ and for complicated rename of unicode filenames I started use XYplorer 18 (https://www.xyplorer.com/product.php). It works very good. :D
tosi
Re: Unicode Support
Post by tosi » 12 Aug 2017, 13:13
+1
thuety
Re: Unicode Support
Post by thuety » 27 Aug 2017, 09:10
This would make the product complete!
camper
Re: Unicode Support
Post by camper » 15 Sep 2017, 16:51
My most complain about AS not supporting unicode is that the Viewer does not support UTF-8.
vygi
Re: Unicode Support
Post by vygi » 18 Sep 2017, 11:10
+1
BTW, I badly need the working WinSCP plugin. It does not work with the new Linux servers anymore as soon as they use OpenSSH newer that 7.1
I've asked for workarounds in the the WinSCP support forum and got following answer:
Yes, the plugin needs to update.
But unfortunately, WinSCP was meanwhile updated to Unicode, what makes it incompatible with Altap Salamander API. I'm waiting for them to release Unicode version of Salamander.
thuety
Re: Unicode Support
Post by thuety » 11 Dec 2017, 10:06
any update?
omega
Re: Unicode Support
Post by omega » 11 Dec 2017, 10:25
thuety wrote:
11 Dec 2017, 10:06
any update?
viewtopic.php?f=4&t=31870&start=30#p61609
