Hide in Find scrolls down
mdruiter
Post by mdruiter »
The selected line in Find is scrolled all down sometimes.
I try:
- search for (find) a very long list of files and folders
- scroll halfway down
- click (select) a file in the middle of the screen
- press Ctrl+H to hide it
The selected line (the next file) is now scrolled down so it is the very last line in the list. :(
This often confuses me. But the most annoying is, that I cannot see the next couple of files. For example, when I work my way from the top down the list, hiding only some, I cannot see what is coming after every hide.
I think this started after a similar situation was fixed, but I am not 100% sure.
Re: Hide in Find scrolls down
Yeah, it looks like the preferred scroll position of the list after Ctrl+H is so that the focused item is at the bottom of the page.
Salamander v3.07
mdruiter wrote:I think this started after a similar situation was fixed, but I am not 100% sure.
Seems that v2.54 is the first one with this behaviour.
