cannot copy or move or edit turkish letter contains files
oguzkilic
Post by oguzkilic »
I tried to copy or edit some turkish letter contains files, but Salamander doesn't work. Do you have any solution for it?
Best regards,
Oguz KILIC
Re: cannot copy or move or edit turkish letter contains file
Salamander does not yet support UNICODE. Search for the word in the forum.
Re: cannot copy or move or edit turkish letter contains files
Depends on if you need to work with any other non-ASCII characters. If not, you can set the default codepage to Turkish and restart. Afterwards, Salamander should be able to work with Turkish filenames. See http://www.altap.cz/salamander/help/sal ... desupport/
