UnEVE Plugin - Plugin for browsing EVE Online Stuff archives
UnEVE is an unpacker plugin for Altap Salamander 2.5 and later that can browse and extract EVE Online Stuff archives.
Please discuss UnEVE plugin in this thread. Comments, suggestions and future request are welcome ;)
Usage:
- Browse Stuff archives in panel by enterring them as folders.
- Extract files by copying them from the Stuff archives to the second panel.
- Unpack whole Stuff archives by using Alt+F9 Unpack command.
Version History:
Version 0.22.29: (2010-01-06)
- Compatible with Altap Salamander 2.52
- Removed all external dependencies
Version 0.21.22: (2009-04-16)
- Compatible with Altap Salamander 2.5 and later (with the exception of 2.52 beta 1)
- Altap Salamander 2.52: Added plugin icon
Version 0.2b1: unreleased
- bugfixes
Version 0.11b1: (2009-03-25)
- bugfixes
Version 0.1b1: (2009-03-23)
- first version
uneve_0.22.29.zip
UnEVE Plugin v0.22. Extract into your "Salamander\plugins" directory and add using Plugin Manager in Salamander.
(17.42 KiB) Downloaded 1082 times
Re: UnEVE Plugin - Plugin for browsing EVE Online Stuff archives
UnEVE plugin was updated to use the new SDK to be compatible with Altap Salamander 2.5 and later versions. (With the exception of Altap Salamander 2.52 beta 1) Download from the first post.
The new version also contains a few bugfixes and a new plugin icon.
For Altap Salamander 2.52 beta 1 continue to use UnEVE 0.11b1.
UnEVE plugin was updated to use the new SDK to be compatible with Altap Salamander 2.52. Download from the first post.
The new version also removes all external dependencies.
