Defaulting to Administrator on startup (2)
Sot23
Post by Sot23 » 01 Oct 2015, 10:59
Hi guys,
just upgraded from 2.54 to 3.06 and found a similar behaviour like the dmonder had a few months ago: the main window title always shows "...3.06 (x64) (Administrator)"
dmonder was able to solve it using simple reboot, which did not make any difference for me:
http://forum.altap.cz/viewtopic.php?f=2&t=8079
  • I'm running Win 7x64 Pro and almost always run everything in user mode, and so the Salamander.
  • The command whoami started from that instance of Salamander returns me as user, not the administrator.
  • To perform one additional check for the rights I tried to create a subdirectory while being in %programfiles% --> "Error: (5) Access denied", as expected when not being admin.
  • I also created a new shortcut at the desktop and double checked Advanced properties: Run as admin = disabled
In addition to that: Configuration > MainWindow > IconColor is set to green to indicate I'm user and not admin. For admin access I created a 2nd shortcut (with "runas") and set the IconColor to red, which works fine. But the main window title always shows "...3.06 (x64) (Administrator)", for both admin as well as user?
Any idea to solve that?
Re: Defaulting to Administrator on startup (2)
Post by therube » 01 Oct 2015, 16:43
With your actual (Run as...) Admin version, what does whoami return?
Does Task Manager, Process Hacker, Process Explorer show anything of note, interest?
Post by therube » 02 Oct 2015, 09:49
whoami:
In both cases, limited & As Admin, whoami reports: ruben-w7-x64\ruben
Though it does show differing privileges:
Mandatory Label\Medium Mandatory Level                        Label            S-1-16-8192
vs
Mandatory Label\High Mandatory Level                          Label            S-1-16-12288
(And then a lot more Privileges Information is reported for the As Admin user too.)
Process Hacker:
Limited: shows Medium integrity
As Admin: shows High integrity
command prompt window:
Limited: normal [does not distinguish]
As Admin: shows Administrator
Sot23
Post by Sot23 » 02 Oct 2015, 11:23
Just checked it right now:
Whoami at user level:
  • shows user
  • whoami /priv shows just a few priviledges
  • Salamander 3 shows "(Administrator)"
Whoami at admin level:
  • shows admin
  • whoami /priv shows really a lot of priviledges
But indeed I'm surprised to see a high mandatory level for both admin and user. :oops:
I have to check how to change this. :?
Post by SvA » 02 Oct 2015, 15:29
please check Config > Main Window > Custom text prefix.
please also check salamander's command line for parameter -T (best use Task Manager, Process Explorer or the like for this check)
