Dropbox icon missing on toolbar and in Change drive menu
Posted: 16 Sep 2015, 11:57
Couple of users have complained to missing Dropbox icon on toolbar and in Change drive menu even when they have Dropbox application installed.
So I have installed latest version of Dropbox and it has configuration in different path than in time when we have added this feature. I have fixed it (it works with both paths), so next released version will work well.
You can use simple fix for current version of Salamander when you copy one file:
-go to (paste it when left panel is active): %LOCALAPPDATA%\Dropbox
-go to (paste it when right panel is active): %APPDATA%
-create directory Dropbox in right panel, go inside it
-copy file host.db from left panel to right panel (create file %APPDATA%\Dropbox\host.db as copy of %LOCALAPPDATA%\Dropbox\host.db)
-exit & start Salamander
-you should see Dropbox icon again
