3.06 hanging after seconds in Win-10 Virtual Machine (OSX)
Robby
Post by Robby »
Hi, I run Win-10 (pro Insider View 10532) in a Parallels VM on OSX 10.10.5
Either the 64 or 32 bit version hang after several minutes. I need to kill the process and restart Salamander. This was not the case some time ago. Could this be caused by a Win-10 update? By a Parallels update?
I really don't have a clue where it's coming from. Robert
Re: 3.06 hanging after seconds in Win-10 Virtual Machine (OS
Maybe WhatIsHang - Get information about Windows software that stopped responding/freezing (hang) could provide some clues?
Run it, save a "hang report" & post a link to it (from like http://pastebin.com/ or similar).
Robby
Post by Robby »
It seems that my problem went away after updating Parallels, Windows etc.
However, I'm going to x-check with the WhatIsHang tool to see if there is something suspicious. Overall the VM is very low-profile with mostly nothing installed.
