Right click context menu intermittently stops working
noetus
Post by noetus »
I have an issue that quite often I am working with AS and the right-click stops working. It doesn't matter where I click on the window (on a folder, on a file, on white space, etc), there is no right-click menu.
If I close and immediately re-open Altap Salamander, right-click is working in both panes again.
Right click does not stop working in the native Windows explorer.
EDIT. Also, when the right-click stops working in one panel, it will work one more time in the other panel, then stop working there too.
Re: Right click context menu intermittently stops working
Can't say I've ever seen that.
Anyhow try, ShellExView - Shell Extensions Manager & Right-click is slow or weird behavior caused by context menu handlers & see if that might be able to point something out?
SuperPlay
Post by SuperPlay »
Hi Folks
Used this excellent product for several years no problem then all of a sudden I started to see the same issue detailed here (tested with versions 3.06/3.07) Windows 10
Then I realized that I had recently installed Spybot (https://www.safer-networking.org/)
So I uninstalled this program and all is working again :D
Thought that I would just share this just in case others are having this issue.
